Old 11-05-2009, 20:30
Default Braided Oil feed question
im gonna make a replacement oil feed for my mk1 engine, i have asked this before, but was never really cleared up, do these oil lines have a restrictor??
http://cgi.ebay.co.uk/Turbo-Oil-Feed...3286.m63.l1177
this kits shows a 1.5mm hole in the feed banjo bolt, is this right?? or do i not need to worry about this on the long mk1 pipe???
i really need to clear this up, as i dont want to spend a load of money on a refubed turbo, and then over oil it etc.
or give me a number of someone that may be able to help.
Cheers guys.
Old 12-05-2009, 10:05
silviagod's Avatar
I would give Turbo Technics a ring, they have been very helpful to me when I have telephoned them.
Old 13-05-2009, 08:28
Smile Oil feed
Hi,
I had one made up for my MK1 with no restrictor in it and had no problems.
I took the old ends to Pirtek and they made me up a line for about £20.
The small holes in the banjo bolt will reduce the flow of oil so you won't over pressurize the turbo.
Cheers
Simon
Old 13-05-2009, 19:11
i wont be using the banjo joints, as mine has screw ends both ends, i just used that as an example.
cheers for the reply though.
