Old 02-06-2009, 21:08
Originally Posted by Noodle_Soup View Post
i have done a coilover conversion on my s12, bought a full set of TEIN coilovers for a s14, (cheaps!!) and the pillow ball top mount was a straight fit on my mk1, i used the lower arms, hubs and tension rods of the s13, mainly as i wanted bigger brakes and calipers and the s14a 4 pots bolt straight to the s13 hubs,
My plan too. Mainly for the adjustment introduced and brake options.
Old 01-07-2011, 10:08
drifter33's Avatar
drifter33 drifter33 is offline
drifter33 is an unknown quantity at this point
hello I would like to know if anyone knows where I can find this nut and washer for the coilovers, I can not find a thank you in advance ^ ^
Old 01-07-2011, 22:12
tim murphy's Avatar
nice suspension strut job thanks for the info
Old 12-07-2011, 15:50
nismo915 nismo915 is offline
nismo915 is an unknown quantity at this point
are you building these kits for members yet??
Old 27-01-2014, 18:32
grahamhumm grahamhumm is offline
grahamhumm is an unknown quantity at this point
Do you do the same with the rear suspension or is it totally different?
Old 19-05-2015, 11:21
Montizuma Montizuma is offline
Montizuma is an unknown quantity at this point
Default Oil amount
Hey guys I've just finished welding on the selves and realised I didn't check how much oil had come out of the buggers, so does anyone know how much I need to add also if motorbike fork oil or ATF is better? Cheers Dan
Edit* ok so they seem to take 450ml of oil I went for fork oil as that's all I could get, but I have ran into a problem where the rally desighn top plate doesn't fit over the strut..... So I can drill them out but do I go to the thread width of 12mil or to the next step up of 20 mil ? Cheers Dan
So basically use 450 ml of fork oil in each strut and you will need to get the top hats from rally design and drill them out to 20 mm or buy them from techno toy tuning as they are 20 mm allready . Cheers dan
Last edited by Montizuma; 09-06-2015 at 06:39. Reason: Answered my own question but found another
