Yeah 14.2 is dangerously lean, the operator shouldn't have even taken it up that far. Leanest you want is 13:1 and even that is a bit borderline.
Don't top speed it, it will wreck a piston.
is that an ET or 16v ?
If your on a budget you could always wack a cheap 5th injector setup on it. In your case it might actually do the trick. Demon tweeks to adjustable pressure switches which would make it more manageable
