Are you saying I need to strip the Three relays/wires out from the loom all the way to the brown/grey connectors??? If so, I see from the relay box on the Nearside that at least One Blue wire goes into a Blue relay from the Grey connector? Is this going to cause problems when cut or is it just spliced back in ???
Yeah I remove from that loom the wires I didn't need. I can't remember what the blue relay was for, but I chucked it out.
You'll end up with a number of black and red wires that feed the relays and the loom for you to put permanent and switched power to. There's also one very thin black wire that needs to be earthed.
![]() Quote:
I also followed the ECU pin diagram to find out for sure what each wire does on the brown and gray plugs. This is what I found
8 Pin grey plug : Red/Silver band ECU 12v perm live PIN 58 Blue/Green silver band A/C relay *NOT USED* Black/White silver band ECU eccs 12v switched PIN 109 Blue/Red Plug loom 12v switched (no pin) Black/Red Ign power 12v switched PIN 45 White (shielded) Knock sensor (I will wire this in further towards the bulkhead) 8 Pin brown plug Green/Yellow silver band A/C relay *NOT USED* Black/Red silver band Eccs power 12v switched PIN 16 Green/Orange silver band Inhibitor relay *NOT USED* Black/Purple Fuel pump relay PIN 18 (NOT SURE WHICH PIN ON THE FUEL PUMP RELAY) Black/Yellow ***** Dont know what this is ???!!**** Brown/silver band O2 heater (my ECU plug does not have an 02 wire) Now I think I have all these correct (if not then say!) but I need to know if my dodgy relay wiring is OK ? Can I run one Permanent Live/One switched 12v/One ground jumped through all the relays ??? ![]()
I recall that some of the relays shared the shame power source even on the standard loom. You only need 3 relays though not 4.
I'd have to look back at my loom to remind myself what I did, but basically the 3 green relays plug in to the engine loom via the brown and grey plugs. You'll find the length of the wiring quite long, you could shorten these if you wanted. I then found there were loose wires going to the relays for power, earth and switched ignition.
Once I'm ready for the transplant and the DET is in, I will shorten the wires accordingly. The 4th relay I put in there is for the Fuel pump or are you saying I could double it up on another ?
The 3 relays there are for the ECU, power transistor (the silver square box) and the fuel pump.
No need for another relay
Thread Tools | |
Display Modes | |
