Old 07-09-2009, 16:15
sjef200sxTurbo's Avatar
sjef200sxTurbo sjef200sxTurbo is offline
sjef200sxTurbo is on a distinguished road
Default weird fuel problem
yesterday my 84 ca18et was running fine, did some donuts everything perfect.
I let it idle for about 15 minutes and then i took of , drifted 1 corner under full trotlle and it suddenly started dipping bad, i tried to get home so i drove with low trotlle gently.then it got worse and i stopped and i felt that there were air bubles in the fuel line between the fuel filter and the fuel rail, after i fiddled with it it ranfine again, thinking it was a clogged up filter,
Today I checked it and i have fuel preasure but now it wont start at all.
Has anyone have this problem before?
87 silvia (ca18det)
94 Alfa Romeo 155 2.0 8v ts (daily driver)(planning Lancia Delta swap)
84 silvia (ca18et oldtimer)
Turbolag is nothing but foreplay
Old 07-09-2009, 16:18
has it dragged shite up from the tank with drifting it ? then blocked the injectors.take your filter off and empty it onto a white piece of paper and see if theres lots of crap.
Old 07-09-2009, 18:36
There was some dirt in the filter but il put in a new one just to be safe.
But i got it running again by blocking of the return fuel line.
Its always under high preasure so i think the fpr is broken, il install a adjustable fpr this week.
87 silvia (ca18det)
Old 07-09-2009, 21:23
Put a multimeter on the injectors and see if you have a pulse and check you have a spark.
How can you feel bubbles in a fuel line?
Old 07-09-2009, 21:38
it runs fine now, I just picked the car up couple weeks ago but was standing still for many years. Most of the time it runs really good , only got 60k on the clock.but the previous owner disasembled a lot of stuf that i had to putt back.
So I had some trouble with things missing and loose (like the distributor came of on the way home)
But it seemed i dave pulled a vacium in my fuel line but my fuel pressure regulator seems to be always on open and under high pressure so im gonna instal an aftermarket adjustable one so i can boost it up a bit safely.
87 silvia (ca18det)
