Old 20-09-2009, 07:49
that looks like a modified mk2 grille with mk1 side lights, i have the mk1 grille, and its like honeycomb effect.
Old 20-09-2009, 14:21
nedge2k nedge2k is offline
Administrator
it is, yeah. always preferred that style to the honeycomb, looks more 80's
Old 20-09-2009, 18:08
Originally Posted by _nedge2k View Post
the kit isn't too bad, there's a couple of paint issues but it seems well fitted enough. the spoiler doesn't feel overly secure.
as for the lights, if you've got a mk2 grille and sidelights, i'll do you a straight swap if you want?
You're on! PM'd.
I wondered if they damaged the underseal or something when it was fitted ?
Old 20-09-2009, 20:32
Administrator
tbh the underseal *looked* ok but as you can see from the pic, there's some black spray over the area - mebbe an attempt to cover up a problem. either way, im just glad the other side is solid. my mate is back off hols now so we should be able to weld that up and the back of the sills soon - just hope it's only the back of the sills or the skirts are gonna have to come off
Old 30-09-2009, 13:34
chris1986 chris1986 is offline
chris1986 is an unknown quantity at this point
hi guys
i was wondering how to get the rear subframe and the rear arms bushings out
how do you guys do it?
greetings, chris
Old 01-10-2009, 08:06
Burn them out
Old 01-10-2009, 10:31
if your having polly bushes, then leave the collar in.
Old 26-11-2009, 13:48
Rear Trailing Arm Bushes for the S12 - Superflex part number SPF0561 on there own or SPF0561K should be a kit, but leave the original collars in.
These appear to be from a 280ZX.
Credit to Shaun and Chris the chap from Superflex.
Ps Shaun your PM was full yesterday!
Old 26-11-2009, 18:10
cheers,sorted now matey.
Old 27-11-2009, 08:01
I also found a cheaper option (just under £40 ) for front control arms (wishbone bushes), I think S13 ones will fit, and I've ordered a set of powerflex ones through Driftworks, unfortunately Powerflex has just has a major fire at their factory so I have no idea when or if I will get the bushes and see if they fit! DOh!
