i would only ever recommend using genuine nissan manifold and turbo gaskets, my opinion is they are the best you can buy and there not that expensive
Will price up at Nissan tomorrow, has anyone got parts numbers for these or do i just ask for S13 Manifold to Turbo Gasket and Turbo to Elbow gaskets?
As long as you get steel gaskets and not made of putty ebay ones then you will be fine.
How stupid is this!!!!!!!!!!
Rang Nissan in Doncaster the parts guy wanted a registration or chassis number to be able to quote on parts, told him it was for an S12 application and he stated "without a registration or chassis number I cannot get into the system". ![]() Couldn't take my registration or chassis number as it would have taken him to the wrong parts screen. |
Rang a Dealer in Sheffield, who gave me the part numbers and a price straight away, he also stated he has a guy who comes in with a white D plate S12 which was his fathers and has been in storage for 8yrs I bet there are a few like this tucked away somewhere.
Turbo to Manifold Gasket: Nissan Part No: 1441517M00 £9.39+vat Turbo to Elbow Gasket: Nissan Part No: 1444526E00 £20.41+vat Had various quotes from the dealers on SXOC Turbodynamics: £15 for the pair .................................................. .......... Japspeed £15 delivered the pair .................................................. ........... Apex Performance Parts Turbo- manifold -£36.73 Turbo - turbo elbow - £35.65 .................................................. ........... Driftworks Turbo - Manifold - £37.29 inc VAT Turbo - Elbow - £33.21 inc VAT Last edited by paulsilv; 16-01-2010 at 17:19. |
what elbow are you using??? s13 or s12??
if you use the s12 one you have to make sure you have the right studs in the turbo, because one stud is in the wrong place and will stop the elbow going on, another stud just isnt used, you use just 3 of the 5, if you use the s13 elbow you may need to cut a lug off the gearbox. if you use the s12 elbow, you can use the s12 turbo to elbow gasket as i have just fitted mine with all s12 exhaust gaskets. when you phone nissan, just tell them to put s12 or s13 in the box marked "model series" you can also put year if you know it mmyy. i have NISSAN FAST installed on my pc so i look up the part numbers before phoneing them, really is much easier.
Thanks umpkin, read all the posts on the T25 and they are quite vague with regards what elbow fits, studs being different, use 3 of the 5 etc.
I'm fitting it with the S12 elbow unless there is a massive power difference in fitting the S13 or an aftermarket one (cutting the lug off the gearbox is not a problem if its needed) Great tip on the NISSAN FAST Software Last edited by paulsilv; 16-01-2010 at 17:32. |
