Old 15-01-2010, 18:05
what elbow are you using??? s13 or s12??
if you use the s12 one you have to make sure you have the right studs in the turbo, because one stud is in the wrong place and will stop the elbow going on, another stud just isnt used, you use just 3 of the 5, if you use the s13 elbow you may need to cut a lug off the gearbox.
if you use the s12 elbow, you can use the s12 turbo to elbow gasket as i have just fitted mine with all s12 exhaust gaskets.
when you phone nissan, just tell them to put s12 or s13 in the box marked "model series" you can also put year if you know it mmyy.
i have NISSAN FAST installed on my pc so i look up the part numbers before phoneing them, really is much easier.
