Fair enough on the cam mate, and had some interest on the crank on sxoc! win! how much for the forward facing manifold? your right the standard inlet plenums are poo and make for hideous piping angles! it looks like the guy who wants the crank doesnt want the bearings, so maybe another for sale thread in a mo!! best to get bearings to suit the crank rather then grind the crank to suit the bearings! you mentioned a rebuild, dont need any race bearings?ha ha! is the cam Gripo has for sale similar profile to yours? only ask as i dont want an all or nothing engine, would rather have smooth delivery as you said have driven cammed turbos before and you spend half your time waiting then the other half holding on for your life! dont get me wrong i like a bit of a kick in the back but i want the car to be useable other then when im giving it beans!!
thread showing the manifold for sale
http://www.nissansilvia.co.uk/vbb/sh...?t=4757&page=4 Gripos cam sale thread http://www.nissansilvia.co.uk/vbb/showthread.php?t=4730 sorry, your bearings wont help me with this rebuild. from memory the stock cam is something like 248deg, 8.8 lift and the Piper is 268 and 10.5mm or similar. the std cams so soft that almost as soon as the engine starts to make good power from the turbo, the cam starts to restrict with little lift and low duration. Your call, but personally without a decent cam the numbers might be there but the power wont be able to be exploited imho. I run the Autosprint cam currently, in fact mine was the first one that Geoff created using my engine spec as the basis. In real terms the Piper or Autosprint will give the improved performance in the range of boosted rpm.
Guess this is still available, what cc are the injectors mate? i currently have 440cc not sure on the maximum hp they will handle with a 255 pump, just checking if the injectors are needed also. is the price delivered?
injectors are 444cc. So long as your pumps up to it and you have an adjustable fuel pressure reg, they should see 300-320hp.
cheers Craig
what engine management are you going to run?
currently have emanage,but im in the midst of doing a deal with FC Tuning for a prototype NIStune solution,all being well it will be a plug and play fully mappable but based on the stock s12 ecu.will keep you posted on that if you like.
Ah, thats fine, just worried with all the hardware mods you were gonna try and use the std clockwork s12 ecu lol.
a plug'n'play would open up the possibilities for lots of guys on here and the scimitar boys too. I run an Emerald ecu at the mo
