Old 22-01-2010, 23:22
Should have had a chat with you before getting stuff done mate, i knackered the crank so thinking a det crank would be easier to get hold of found one, and had it checked,ground and balanced and then bought bearings to suit!unfortuneatley the oil pump is for the ET so gotta real mis match going on! will stick a post on here and DW to see if i can get a decent ET crank, i imagine they are even rarer! i didnt wanna drill the rods but it was another idea thrown into the mix as a possible solution. will stick with the ET sump as i dont like the oil surge ideas and im pretty impressed with the 1.95 G acceleration! thats why i wanna stay 8v, prefer the torque curve! last time mine was on the rollers it was 183bhp and 195ftlbs torque (at 4,500rpm as i had a dodgy coil!) whats yours kicking out?
I do have a spare ET engine basically complete but didnt wanna rip it apart just to rob the crank, as it is still possible that i could encounter the same issues with a sticky crank gears!
Old 23-01-2010, 11:44
yeah, they produce some good torque, mine made 325ft/lbs .
Old 23-01-2010, 18:23
i will ask around our guys for a spare ET crank, sure someone will have one
S13 Eaters is the daddy on the figures, mines only 282hp/266lb/ft but thats only with a responsive Turbo Technics T28 hybrid @ 15psi. The ET is much underrated and overlooked by the DET. ive got some decent bits left if you fancy them? the turbo, Canadian fwd facing manifold and modified head and cam etc
a good DET crank with bearings would sell on sxoc a piece of pi55
Old 23-01-2010, 20:40
if you could ask around for a crank that would be ace. Might be interested in the cam mate, how different is it to standard?im running a custom four branch top mount manifold and a IHI hybrid roller bearing TD05. and have an eight spark head which has been ported and polished.Bit concerned that i wont get the right monies for the crank and bearings, i mean the bearings were in the region of £150!!might get an ET crank ground to suit the bearings. Yours is still kicking out brave for the boost your running, im hoping to be running a bit more then 15psi, is that regs or reliability making you run that boost? seems i might have managed to find some squirters. the machining done on your blocks to take them was done on a milling machine im guessing, dont suppose you would have any specs, measurements for where they were drilled? i mean the pics help but bit hard to scale from there! are you running a modified cam in yours? just wondering if thats why your torque curve is less then the BHP at the top end.
Old 24-01-2010, 00:06
sorry, i want to flog the cam and head complete really, but Gripo on here has a brand new Piper cam for sale cheap.
power delivery has always been more importnat to me than max numbers, the way it comes on boost and the shape of the curve makes as much difference to the times as the actual bhp. In the end 15psi came from the most i could get at last dyno session on the external wastegate spring and boostsolenoid. Always planned to run more boost, but have decided to rebuild the car from the ground up following a pretty hefty shunt and go in a different direction on the engine (current class means i can run any engine). Had planned to run approx 21-23psi which i reckon would have seen around 315bhp.
Cams make a lot of difference to power delivery, as does the inlet manifold. Std cam strangles breathing over 5k rpm, and allow you can make the same figures as with a hotter cam, you have to shove loads more boost doen its neck which does nothing for the EGTs or reliability.
Inlet manifold again strangles things. The fwd facing type are much larger volume and allow shorter and neater intercooler pipe runs. I saw about 15bhp and 25lb/ft of torque when i added my current manifold. See pics in project section and for sale section.
the blocks were all machined by a friend who has a precision engineering firm. I gave him a DET block to use as a basis. Gotta be careful as you have to machine thru into the main oil gallery and close to other critical areas. I paid about £100 per block, but that was 5 years ago.
Old 24-01-2010, 00:10
one of our guys has a crank from an engine that the HG blew on so hes gonna pull it out and have a look at the condition of it. Will keep ya posted.
i had a tubular top mount manifold, and again frees up breathing at higher boost (1bar+) but if not used with a cam as well it may be a bit disappointing. The tubulars make the turbo come on boost about 250+rpm later, so without the ability to exploit the benefits of the extra breathing of the tubular manifold (bigger turbo, better cam and inlet manifold imho), the worth of the manifold is compromised. Does make turbo access much better though!
Old 24-01-2010, 22:06
Fair enough on the cam mate, and had some interest on the crank on sxoc! win! how much for the forward facing manifold? your right the standard inlet plenums are poo and make for hideous piping angles! it looks like the guy who wants the crank doesnt want the bearings, so maybe another for sale thread in a mo!! best to get bearings to suit the crank rather then grind the crank to suit the bearings! you mentioned a rebuild, dont need any race bearings?ha ha! is the cam Gripo has for sale similar profile to yours? only ask as i dont want an all or nothing engine, would rather have smooth delivery as you said have driven cammed turbos before and you spend half your time waiting then the other half holding on for your life! dont get me wrong i like a bit of a kick in the back but i want the car to be useable other then when im giving it beans!!
Old 24-01-2010, 22:38
thread showing the manifold for sale
http://www.nissansilvia.co.uk/vbb/sh...?t=4757&page=4
Gripos cam sale thread
http://www.nissansilvia.co.uk/vbb/showthread.php?t=4730
sorry, your bearings wont help me with this rebuild.
from memory the stock cam is something like 248deg, 8.8 lift and the Piper is 268 and 10.5mm or similar. the std cams so soft that almost as soon as the engine starts to make good power from the turbo, the cam starts to restrict with little lift and low duration. Your call, but personally without a decent cam the numbers might be there but the power wont be able to be exploited imho.
I run the Autosprint cam currently, in fact mine was the first one that Geoff created using my engine spec as the basis. In real terms the Piper or Autosprint will give the improved performance in the range of boosted rpm.
Old 24-01-2010, 23:01
Guess this is still available, what cc are the injectors mate? i currently have 440cc not sure on the maximum hp they will handle with a 255 pump, just checking if the injectors are needed also. is the price delivered?
Old 24-01-2010, 23:17
injectors are 444cc. So long as your pumps up to it and you have an adjustable fuel pressure reg, they should see 300-320hp.
cheers
Craig
