Old 12-05-2010, 21:54
Default Air regulator/IACV trouble
Hi guys,
I tried to fix my idle. In cold situation, the idle doesn't go over 1000rpms according the FSM, it must go to 1500rpms range than reduce slowly to 750rpms+/-50. Mine oscilates between 650/800,
I tried to find a ECU code error, nothing. I tried to find a leak, nothing too. So i tested different sensors:MAF, water temp, detonation sensor, spark plugs+wires, timing and distributor rotor and stator, no success.
So i tested the IACV/air regulator thing. According the FSM the device itself must have continuity between the 2 pins, not mine.
I bought a second hand IACV, it doesn't have the continuity, according the seller it came from a car that runned good.
So i'd like to know if someone has a good cold start, how it shows on your tachymeter and if he can test the continuity between the 2 pins on it.
I'll appreciate that
Old 13-05-2010, 11:09
seb.racing's Avatar
seb.racing seb.racing is offline
seb.racing is an unknown quantity at this point
le réglage du ralenti, ce fait moteur chaud
évite d'utilisé le compte-tour tableau de bord comme référence
moi j'utilise le compt-tour digital de ma lampe strombe
Old 13-05-2010, 11:14
In hot condition, the idle is ok and i don't have a timing light gun with a rpms function.
Old 01-06-2010, 01:11
my car is exactly the same I fitted one off an s13 but it turns out that one was broken too
Old 01-06-2010, 12:03
Seems the s13 iacv is different, a small hole between the holes for the bolts, right?
Someday i'll try to block the upperhose to feint the system.
Old 01-06-2010, 13:34
To be honest i hadn't noticed a difference just know it still doesn't work. Nissan can supply me a new one but it costs £120+
