Stoned post! ok so you have spark, and its misfiring. fuel and compression tests next.
get an automotive bulb a resistor with the same impedance as the injectors [sevice manual]and some wire, disconnect the injectors and connect each injector wire in turn to the bulb, and crank the engine. light = ok, and vice-versa. Give that its running atall can assume with reasonable safety the ecu is fine, and inconsistent readings here wouldindicate some bad wiring for the injectors themselves, download the service manual and refer to the fuelling section for the test [you'll need a multimeter] Last edited by Dr Silvia; 21-05-2010 at 00:24. |
oh... where can i get one of these british shed inventions? :-)
Maplin/RS and your local motor factor [not halfrauds]
i have a multimeter already... what about the other invention? is is called something as a complete device or do i buy parts?
sorry im on a learning curve here. cheers |
erm, well theres a special tool which consists of those bits, god knows what they called it though. I'm not into paying excess if i can heath robinson something together. the resistor and you multimeter on continuity mode would do the trick in most cases too.
Is it just my PC or does it sound like that's not missing once the engine actually gathers pace?
You could also try checking the ECU for fault codes.
http://www.nissansilvia.co.uk/vbb/sh...ht=fault+codes
