Old 21-05-2010, 01:40
Dr Silvia's Avatar
Maplin/RS and your local motor factor [not halfrauds]
Old 21-05-2010, 10:42
i have a multimeter already... what about the other invention? is is called something as a complete device or do i buy parts?
sorry im on a learning curve here.
cheers
Old 21-05-2010, 10:59
Dr Silvia's Avatar
erm, well theres a special tool which consists of those bits, god knows what they called it though. I'm not into paying excess if i can heath robinson something together. the resistor and you multimeter on continuity mode would do the trick in most cases too.
Old 21-05-2010, 12:06
Is it just my PC or does it sound like that's not missing once the engine actually gathers pace?
Old 21-05-2010, 12:16
You could also try checking the ECU for fault codes.
http://www.nissansilvia.co.uk/vbb/sh...ht=fault+codes
Old 21-05-2010, 13:06
Dr Silvia's Avatar
lo-fi web video doesnt help, but it does seem less pronounced, hence the compression test.
Old 22-05-2010, 14:25
i got the plugs out today...
no.4 is slightly rusty on the top and blackened at the spark end
no.3 was wet from oil, blackened and not so tight as the others
no.2 was blackened
no.1 was blackened and was impossible to get off as it was on so tight
http://img269.imageshack.us/i/22052010392.jpg/
http://img525.imageshack.us/i/22052010391.jpg/
but this is probably due to sustained missing from trying to fix it? its no.3 i am concerned about. i split a load of oil on the rocker cover through filling up with oil the week before, then after that run it sat for a week which is when it buggered up after 3-5 mins of warming up... maybe the oil heated up and got in there?
also the spark plugs are set to .70mm. in this post alundra shows a picture of the 'stock' plugs gap to be 1mm: http://www.nissansilvia.co.uk/vbb/showthread.php?t=5027
Old 24-05-2010, 22:11
check inside the dizzy cap. i have had the center contact jump out before now
