Old 06-01-2006, 13:50
Shaun the pic of the caliper hasn't got the pad spacers fitted but it has got the original shims fitted.
Old 13-03-2006, 10:38
Dan Dan is offline
Northener, just an idea but would you be able to make up some spacers for me if i buy some s14 calipers?
(sorry to drag up an old thread)
Old 13-03-2006, 10:57
Could do but there not much involved in doing it. I just got some 4mm ali cut locally. Use the Pad shim as a template and draw round it and then cut it and file it down, Job done. Suppose I could make a load of them but ATM its too cold and its the time factor. I might have some 4mm ali left I'll have a look and see !
Old 13-03-2006, 10:59
Dan Dan is offline
Cool, it wouldnt have to be done soon, just making sure before i think about buying these. How much did you pay for your 4 pots?
Old 13-03-2006, 22:13
I was lucky I paid £80 but had to collect from M25 South as the guy was braking a 98 S14 on www.sxoc.co.uk. I painted them Red and they look fab!
Old 13-03-2006, 22:52
lee@ lee@ is offline
S12oc Newbie
lee@ is an unknown quantity at this point
just a thought but how thick is the S14 pad without brake material on it?
Old 14-03-2006, 01:07
Yeh I thought of using an old one but could be bothered getting involved with hacking off all the old material and breathing it in whilst doing so !
Old 14-03-2006, 20:01
S12KWA S12KWA is offline
S12KWA is on a distinguished road
What size wheels do you have to use with S14 caliper's?
Will they clear the standard 15"?
Old 14-03-2006, 20:30
The do clear 15's as long as you use a Minimum of 10mm spacers on the fronts with longer studs !
Old 15-08-2007, 21:48
old-and-rusty's Avatar
Hiya Northerner,
It looks like a superb set up .
Do you think there will be enough clearance for 16`s without the need for spacers (that`s what I`ve currently got on my s12).
Regards,
Ian.
