Old 29-07-2010, 08:51
PureButeS12's Avatar
Default boost problem
hi all, last week my S12 stopped boosting all together, it wasnt even registering negative boost, but after a quick look under the bonnet i found one of the vaccum hoses had split (assuming because of age) so i repaired it
it worked fine for a week but now its stopped boosting again
this time the boost guage is still reading negative boost as normal but won't go above zero when driving, so am guessing this isnt another vaccum problem cos the guage would of just stayed at zero on tick over
the boost pipes all look secure, actutor arm isnt stuck, i think the dumpvalve is fine too, could this be a problem with the safety valve on the intake manifold or something else???
any advice would be greatly appreciated
custom front coilovers, -40mm rear springs, de-spoilered, Bailey dump valve, induction kit, mocal sandwich plate with oil cooler, OMP deep dish steering wheel, unknown jap 14x8" slotmags from 1976
Old 29-07-2010, 09:35
check your actuator is'nt stuck open.
Old 29-07-2010, 10:02
the other thing is disconnect the small pipe to the boost sensor whilst the engine is running and reconnect it and it should work.
Old 30-07-2010, 08:12
i don't get it but its fixed itself???? maybe the actuator or something has come unstuck, thanks for advice
