Old 12-08-2010, 20:26
Default New Front Brake Upgrade!
As the car if off the road while i do some engine work i thought i would upgrade the front brakes as i was given a DB Power M3 disc kit for a s13!
Old set up
New set up
Old 12-08-2010, 20:31
WOW bet that stops. Are the brackets for an S13 ? Do the redrilled discs go over the standard Silvia hubs or would I need them machined as you did ?
Old 12-08-2010, 21:31
are they the 315mm ones matey ? i use the r32 298mm with the r32 calipers.
Old 13-08-2010, 15:54
northerner the brakets are for a s13, the kit comes with extra spacers but they are not needed on s12, I think they would probably go over the hubs without machining, will check tomorrow for you.
s13eater, they are the 315 kit. dan at db power can get pads now that work with the s14 callipers that optimise the surface area of the big discs as there is some wasted disc with normal s14 pads but still a good upgrade
Old 13-08-2010, 21:55
Draconis's Avatar
Draconis Draconis is offline
Top work! I really need to read up on your brake tech over here. Some seriously good stuff!
Old 26-03-2011, 19:58
paulsilv's Avatar
paulsilv paulsilv is offline
is your front setup all S12 with S14 calipers and the DB Power M3 disc kit?
looking for a bolt on upgrade
Old 28-03-2011, 16:54
s12sweden's Avatar
Wery good stuff you have on your S12 l like it
http://s12ofsweden.com/
Nissan 180zx, Silvia, Gazelle , S12 CA18ET
http://www.garaget.org/s12
Old 03-04-2011, 11:59
yea it is paulsilv
