Old 12-09-2010, 14:33
s12pickup s12pickup is offline
s12pickup is an unknown quantity at this point
Default turbo chatter?
new to turbos.just piped in a front mounted intercooler.when i let of revs i get a shuddering sort of noise from turbo area.didnt get this before(or it was not as loud so i couldnt hear it)read about it on wikipedia and it says its either air gettin pushed back through turbo as you let off revs or the wastegate.which is it most likely to be and can it damage anything .thanks
Old 12-09-2010, 15:01
its turbo chatter matey, as it says, air rushing back over the blades, can cause turbo stalling, dump valves can protect against this.
Old 12-09-2010, 15:22
Default turbo
ill get hold of a dump valve this week then.just tryin to get things sorted b4 i start altering boost pressure.couple of joints keep blowing off on intercooler pipes,going to put them on tool tomorrow to put ridge round were silicon pipes join them .hopefully should be good then.cheers for that any way.
Old 12-09-2010, 15:40
gripo's Avatar
gripo gripo is offline
i have one for sale. Its a bailey - in the for sale section
Old 12-09-2010, 16:07
Default dump valve
mates got a couple of his old cars what he took off b4 he sold them.finding em out for me as i type.cheers anyway
Old 12-09-2010, 16:44
Make sure its a piston type or it will cause loads of problems like idle and will run lean
Old 12-09-2010, 18:54
Default dump valve
ok thanks.
Old 13-09-2010, 13:03
marcusp88 marcusp88 is offline
marcusp88 is an unknown quantity at this point
In my opinion the backspin sounds alot better than a tacky dump valve
Old 13-09-2010, 16:57
Default re dump valve
dont mind sound of backspin but apparently can cause damage to turbo ,or it to stall.dump valve reduces risk of this.(this is what ive been informed).cheers
Old 13-09-2010, 18:26
What boost pressure are you running?
Its not nessesery on a T2 and mine never stalls, id save you money for something else
