Old 20-09-2010, 07:04
PureButeS12's Avatar
Default engine mount query
hi, i think one of the engine mounts has gone on my s12 as the engine is very "jiggly" in neutral
does anyone know where i can get replacement mounts from or are they the same as s13 & s14 mounts?
cheers
custom front coilovers, -40mm rear springs, de-spoilered, Bailey dump valve, induction kit, mocal sandwich plate with oil cooler, OMP deep dish steering wheel, unknown jap 14x8" slotmags from 1976
Old 20-09-2010, 08:14
You can use S13's as direct replacements BUT you would almost certainly have to remove the front subframe as you cant get to the nut to remove the S12 one. I couldnt even get to them with the engine out!
Old 20-09-2010, 09:19
i've changed them before with the engine in matey, 17mm ring spanner, but take a bit of the angle off of it by bending it in the vice then it fits up better.
Old 20-09-2010, 16:15
H'mmm wish I known about that
Old 20-09-2010, 18:19
mmm... cheers for the advice, but i mite just see if i can get a replacement s12 one from sumwhere. do they often give up?
Old 23-09-2010, 20:47
My choice tool is a ratchet spanner with a wobble head . . . easy Well still a right pain to do but possible.
You can use S13 ones and swap the engine mount bracket over to S13 ones. Or make simple adaptor plates that pick up on the S12 engine mount brackets and the S13 engine mounts. If you can drill holes in a plate you can do it.
You can also use universal bobbin ones aswell if you want to do it on the cheap.
Old 23-09-2010, 20:59
get some uprated escort ones from ralley designs, just a solid block of rubber and stiffer than the oem ones.lots cheaper too.
Old 23-09-2010, 23:51
paulsilv's Avatar
paulsilv paulsilv is offline
Which one are you referring to on their website Shaun?
http://www.rallydesign.co.uk/advance...sort=2a&page=1
Old 24-09-2010, 17:28
cheers for the advide, this am gonna go custom & get sum rally ones when i get the chance
has any1 else experienced having a wobbly engine? haha
