Go Back   S12OC UK Forum > Main Categories > Links
Old 09-10-2010, 01:09
paulsilv's Avatar
paulsilv paulsilv is offline
Default MMR-Direct
http://www.mmr-direct.com/
Tension Rod Bushings
UHMW bushings replace the stock rubber bushings for improved steering response and feel.
Front Control Arm Bushings
Delrin bushings replace the stock rubber bushings for improved steering response and feel. Includes UHMW tension rod bushings and new stainless steel inner liners.
Rear Control Arm Bushings (IRS)
Rear control arm bushings are made from Delrin and reduce camber and toe changes under acceleration, cornering and braking. Includes new inner liners.
Rear Subframe Mounts (IRS)
Solid rear subframe bushings reduce subframe movement and improve handling. These bushings are machined from unbreakable UHMW Polyethylene with a precision bored center hole for an exact fit. These bushings can be installed so that the subframe is raised and there is a slight decrease in negative camber.
Steering Rack Mount
Replaces rubber passenger side rack mount for improved steering feel. Machined from UHMW.
UHMW Transmission Mount
Our UHMW transmission mount is machined from a solid block of Polyethylene. It greatly reduces transmission movement which results in fewer missed shifts while still isolating the driver from most drivetrain noise. This mount is virtually unbreakable and should last the life of the car.
Differential Mount
Replaces rubber factory differential mount. Reduces subframe movement under acceleration. Machined from UHMW.
Old 17-03-2020, 19:02
SimonMitch SimonMitch is offline
SimonMitch is an unknown quantity at this point
This website doesn't exist any more
