Old 22-09-2011, 02:49
Default Injectors.
I've had a quick search and can't find anything, so can anyone help with which injectors would make for a good upgrade for the ET? Only that I note in the beginners guide to tuning, it says that S13 injectors or 444cc (yellows) from the skyline will fit? And I notice that the s13 and 444's are both interferance fit, and the ET are the bolt in type?
Is it relatively easy to modify the DET rail etc to get them to fit? Or do you guys know a trick I don't?!
Old 22-09-2011, 08:48
the 12 injectors are barbed on the end, the 444's have an o ring that goes into the rail, i used the 444's the same as the s12 injectors fitted, you just have to force the rubber hose over as i think the 444's are about 10mm and the 12's are about 8mm.
Old 22-09-2011, 11:25
Oh ideal, so you can still use the bolt in flange type affair the same as the ET injectors then. If I understand correctly? Just with the O-rings from the 444's?
Old 22-09-2011, 21:16
just don't use the o rings, push the hose over and use a small jubilee clip on it,
Old 24-09-2011, 17:47
At the top you mean? Got that.
I was more concerned about the bottom, as the injector pockets on the CA18ET seem to bolt in, where as the CA18DET they slide in? And the fuel rail holds them in. Where as that appears not to be the case on the ET...unless I've missed something looking at it?
Old 24-09-2011, 18:52
i'am sure that on my 444's that you could use the rubber from off of the s12 injectors and slide the hard black plastic collars over.
Old 26-09-2011, 19:40
Yeah? Thats another thing worth knowing
So what happens to the little diamond shaped bolt in flange on the ET? Whee part? Or do they still need to be in there?
And I'm afraid I still don't get what holds the 444 injectors in? Because as I say the fuel rail "clamps" the standard DET ones in?
Old 27-09-2011, 10:38
i'am sure the 444's fit the same when you put the band of rubber and the black hard plastic collars on.in fact i had s13 375's in before the 444's and they fitted the same, take an s12 injector out and put them side by side, then just swap the mounting bits over, you'll see what i mean.don't get the collars mixed up, if i remember ,one of the collars that bolt onto the inlet has a different bolt pattern.
Old 27-09-2011, 18:17
Cool, I've got a set of 375's so for a test fit and preobably for the mod's I'm going to run for a minute they will be ok.
Worth knowing one of the collars is different though!
A little gem of knowledge as always. Cheers mate.
