http://www.ebay.co.uk/itm/MOTORSPORT...item5d30a4c98a
SPEC: Length - approx. 181mm Width - approx. 77mm Height - approx. 167mm Weight - approx. 5.3Kg Terminals - 12x12x1.2mm flat blade, 6mm diameter hole Completely sealed Lead-Acid battery Maintenance Free. Not sure whether to go for the Odyssey Racing 25 instead though, something with a bit of history and researchable background ![]() Voltage: 12 20hr Cap/Ah: 16 Weight Kgs: 7 Dimensions (LxWxH): 184.7x79x169.4mm Terminations: M6 Receptacle Last edited by paulsilv; 08-10-2011 at 19:48. |
Ok finally got my arse into gear on this and ordered a positive battery cable from a BMW E39, as the battery in them sits in the boot.
420cm long, delivered for £43. A lot cheaper than buying a race battery and cheaper than buying the cable and parts new. Just need a cheap battery box now Last edited by paulsilv; 31-10-2011 at 23:15. |
