#11
8 FUCKIN VALVE POWER, KICKS ASS lol.325 feckin lbs/ft,
Awesome numbers.
Excellent Results and that max power figure isnt too far up in the rpm.
![]() Quote:
#14
yeah, i'am wondering if timing the cam in will take it up the rev range, i'am a bit confused really cos piper told me that the std cam was 256/108 degrees, and the piper item was a 268/110 degrees, but i think martin said that std was 110 degrees and piper was 112 degrees, i ant got me manual here to check, can anyone check there manual if possible.
i'll ring piper again 2mz for the spec of there's.
Adjusting the cam will only make a small difference. The pipe cam is set to 110 degs and the standard one is 112 degs
i suppose you have to try anything when your chasing those last few horses.
mad figures and all that from an 8 valver
#18
take it thats flywheel power....
#19
i should think so yeah. Awesome results.
![]() Quote:
#20
yeah, according to wrc technologies at silverstone the place where i hade it dyno'd before use a marha set up and it reads 5% more which would have given me about 321bhp, i also had a RR read 9bhp more than the marha which would be about 330bhp, its good bhp for an 8 valve, but all rollers are different so its no use comparing unless the cars are on the RR on the same day.
