Thanks guys.
So the gain adjusts the time of the opening of the wastegate then? i think i have the gain set at flat out..... so i will adjust that tommorow. also theres a setting on the back that says wg or act? i have seen that clutch Rob. it is an idea. my exedy clutch is holding at the moment.Hopefully it will last a few months
yes jon, thats for either an external wastegaste or an actuator, its gonna spike like feck if you have your gain on full, if you want a lot of gain you have to turn boost down as it raises your peak boost.
Thread Tools | |
Display Modes | |
