Old 12-10-2012, 20:23
paulsilv's Avatar
paulsilv paulsilv is offline
Here we go guys, every part I used:
S13 Coilovers (I used Apex Performance ones)
S13 LCAs
S13 balljoints
S14 ARB
S14 ARB brackets
S14 Tension Rod Brackets (one hole needs redrilling easy job)
S13 Tension rods ( I picked up some Japspeed aftermarket ones cheap)
S14 Droplinks
S14 Tein inner and outer track rods.
I came across 2 problems
1) I originally bought S13 inner and outer track rods which are too short.
2) I had to buy 2 bolts from Nissan to attach the Tension rods to the Tension rod brackets. This was about £18, expensive but at least I know they are the right bolts.
I have gone with Skyline R33 GTST front calipers and discs, which bolt straight on to the S13 stuff. Only problem I found was the calipers hit the back of the spokes on my 17" 7.0j Lenso RS5 alloys ET42. This is most definately a wheel spoke design problem, and not a problem with the setup. The original 15" wheels fit over these calipers but have the same problem hitting the back of the spokes. I could use wheel spacers to clear the calipers, but this would then push the wheels out of the arches by about an inch. I have managed to pick up a set of ENKEI PR01 wheels ET32 7.5j front and 8.0j rears off a Skyline which should be fine. They turned up with a courier yesterday but I haven't had chance to try them yet.
If they clear the calipers but sit outside the arches I will fit some arch flares, but that's another thread
Old 15-10-2012, 17:57
nedge2k nedge2k is offline
Administrator
copied your post here in case it gets missed
1985 Mk1 Black Auto
1989 Mk2 Red Auto
1988 Mk2 Blue Manual
1988 Mk2 Blue Manual (Donor)
Old 30-10-2012, 13:58
paulsilv's Avatar
good stuff, didnt think to pop it in this section.
I have trial fitted the Enkei PR01 wheels i won on ebay for £124 with tyres and they now clear the R33 GTST calipers fine.
So i will now have mega brakes with the Skyline setup. Think they look quite Retro also.
Old 30-10-2012, 19:40
looking good paul, keep up the good work matey .
Old 30-10-2012, 21:35
tim murphy's Avatar
makes the silvia looks fine paul . cheers
