Old 30-01-2013, 09:18
lmrdave's Avatar
lmrdave lmrdave is offline
I have a pair of front wishbones with new powerflex bushes fitted, thats what I did.
They have never been on the car. I was going to go back to running S12 arms, but realised I'd gone away from them for a reason. so not much use to me, unless my new S13 arms turn out to be early ones.
Link
Old 02-02-2013, 18:38
Default S12 arms
Why have you gone away from S12 arms?? How much do you want for them?
I have fitted all the front bushes excluding the arms and can confirm they all fit perfectly they are the part numbers from the list but I will post the exact new numbers from the packets as they are slightly different from the original post on this thread.
!!!!!! A word of caution the tie rod arms did not come with the metal sleeve insert and I had to get them made by a local engineering firm, Clifton Engineering, Coopies Lane Industrial Estate, Morpeth, Northumberland. They charged me £20 for the two !! The original ones were rotten and split hence the steering issues I was having which is now cured. Even the drop link bolts were rotten and probably original 24 years old!! I just bought some matched bolts for £2 and everything is spot on as I got the tracking laser set too by Kwik Fit £31.95 although they didn't have the settings for an S12 they just set at 0 parallel
