  #31
Old 02-02-2013, 18:38
Default S12 arms
Why have you gone away from S12 arms?? How much do you want for them?
I have fitted all the front bushes excluding the arms and can confirm they all fit perfectly they are the part numbers from the list but I will post the exact new numbers from the packets as they are slightly different from the original post on this thread.
!!!!!! A word of caution the tie rod arms did not come with the metal sleeve insert and I had to get them made by a local engineering firm, Clifton Engineering, Coopies Lane Industrial Estate, Morpeth, Northumberland. They charged me £20 for the two !! The original ones were rotten and split hence the steering issues I was having which is now cured. Even the drop link bolts were rotten and probably original 24 years old!! I just bought some matched bolts for £2 and everything is spot on as I got the tracking laser set too by Kwik Fit £31.95 although they didn't have the settings for an S12 they just set at 0 parallel
