Old 15-08-2013, 11:43
Austin666 Austin666 is offline
Austin666 is an unknown quantity at this point
Default New owner saying hello
Hello everyone ,
My name is Sean i have recently bought a red s12 with 40k on the clock will, problem is it need a new clutch. The car came with a clutch that will need fitting but it is for a 2.0 will this item fit the 1.8.
Thanks for any help/advice
Old 15-08-2013, 18:06
tss240zg tss240zg is offline
Hi mate
The clutch you have is for the FJ20 engine, I dont think the Fj clutch fits the CA18
Somebody will correct me if I am wrong
Old 15-08-2013, 19:20
tim murphy's Avatar
hi i thinking the 18 and 2litle clutch is the same engine blocks the same pistons are bigger size measure clutch plate across on each . cheers ps welcome to the s12 site
Old 15-08-2013, 19:22
I dont think the clutches the same - there are more bolts on the FJ20 one holding it on than the CA18. Unless of course 2.0 litre one is off a CA20
Old 15-08-2013, 19:24
FJ20 has a much larger clutch
I know this as I have both engines
Old 16-08-2013, 19:40
cheers people , i think i will buy a new one the box looks like its been sat in a damp garage for years.
p.s that manifold nut is a right bugger to get at , got to change the turbo as this one is seized
Old 16-08-2013, 20:58
nedge2k nedge2k is offline
Administrator
i've found chopping a cheap spanner in half with an angle grinder does the trick nicely. the biggest pain is getting the water feed pipes away from the back of the head without bending them - you can try taking them off the turbo in situ but it's easier to disconnect them from the inlet side of the head.
1985 Mk1 Black Auto
1989 Mk2 Red Auto
1988 Mk2 Blue Manual
1988 Mk2 Blue Manual (Donor)
Old 21-08-2013, 12:12
t3nhps12 t3nhps12 is offline
t3nhps12 is an unknown quantity at this point
Talking new to the forum
alright mate good to see your getting on with the work, we spoke on the dw forum
get a build thread going so we can all see how you are getting on
Old 22-08-2013, 08:40
cheers for the help guys im just struggling to get the oil feed full tightened in the turbo then i should be good to go
