Old 22-08-2013, 03:01
Default CA18DET swap, am i doing it right?!
Some of you may have seen, I got a CA18DET a couple of weeks back. I've managed to get it in and semi-wired up. According to pukkas swap thread you only need the 3 green relays, but I've used the relays and the fuses from the S13 loom I got, seemed easier to me.
I dug out the wiring diagram and simplified it...
my questions is did i need to use this?
all i needed to connect up was a line from the battery, and ignition from the connector that powered up the old engine loom. Only problem now is theres alot of wiring that i need to neaten up as you can see lol
I have still to connect up a few other things but just though I'd get some opinions, currently i managed to get it to run a little using engine start as I haven't done the fuel pump yet, still figuring that out.
