regarding the wipers, if you can't find anything, just buy some of the same length and take the blade out the front ones are a std type still used today, the rear is a little different.
1989 Mk2 Red Auto 1988 Mk2 Blue Manual 1988 Mk2 Red Auto (Ex-Silviagod) 1988 Mk2 Blue Manual (Donor) Last edited by nedge2k; 31-10-2013 at 21:59. |
thanks for the hint,but as long as i have the slightest chance to get my hands on an original,i don`t want to do that...
by the way,what is that Motec you just mentioned?
Standalone ECU, a bit over the top for most applications. A DTA ECU is much better value for money at ?600-1150 depending on spec.
1989 Mk2 Red Auto 1988 Mk2 Blue Manual 1988 Mk2 Red Auto (Ex-Silviagod) 1988 Mk2 Blue Manual (Donor) Last edited by nedge2k; 06-11-2013 at 08:57. |
that sounds good.so there are special ecu-s for s12.where can you get them,and how reliable they are?any personal encounters with those?
No they are generic ECUs for all cars - you'd need to either modify your wiring loom or have one made to suit it and then get it mapped on a dyno.
I have a DTA S100 for another project of mine but my S12 will eventually run an S60. http://www.dtafast.co.uk/compare_ECUs.htm
1989 Mk2 Red Auto 1988 Mk2 Blue Manual 1988 Mk2 Red Auto (Ex-Silviagod) 1988 Mk2 Blue Manual (Donor) Last edited by nedge2k; 01-11-2013 at 22:29. |
