Old 11-11-2013, 21:20
tim murphy's Avatar
Default alloy radiators
hi thinking about getting a new rad four my silvia has any one got info about good ones to use thinking about a aluminium one. trouble is both hoses are on same side . may be ones that have been use on s12 . cheers
Old 15-11-2013, 22:27
mk3 golf rads are alloy and have the in and outlet on the same side
Old 17-11-2013, 02:51
sideways_s12 sideways_s12 is offline
sideways_s12 is an unknown quantity at this point
Mishimoto has rads you have to get it for the ka24de that came in the 240 here in the states that's what I'm going to be running. there not that expensive under $200 usd not sure what the shipping would cost to get it to you tho... I got mine off egay lol
Old 17-11-2013, 12:25
tim murphy's Avatar
got two old rads in my garage maybe get one recond . look into the one's on ebay cheers for the info
Old 18-11-2013, 03:40
no problem!
Old 22-11-2013, 11:09
s14 ally rads are good because they are not quite as wide and you can feed i/c pipes straight past it, i use a 52mm s14 ally rad, the pipes are on opposite sides but its an easy fix with some silicone bends.
Old 12-12-2013, 10:41
watson514 watson514 is offline
watson514 is an unknown quantity at this point
Default My radiator key does not fit!!!?
I have bought a new key and it only fits and turns in 1 radiator and not the others. My radiator clearly needs bleeding as the bottom half is hot only.
I am not sure how to fix this. Any suggestions?
Spare Parts
Old 12-12-2013, 14:24
tim murphy's Avatar
sounds like it needs recoring that wot I got done to mine the bad news it cost 150 comes with a 2 year wart cheers
Old 12-12-2013, 14:42
i would'nt wast my time having it recored when you can get an s14 52mm alloy rad for around ?120 and its good for running intercooler pipes straight down the sides to the front.
