Old 21-05-2014, 19:13
Here's a question, when setting the timing is this correct:
Bottom pulley to 15 degrees
Set distributor to one gear out to the notch and install
Or set the set the bottom pulley to 0 tdc and then align the dizzy to give me 15 degrees when the engine is running?
Old 21-05-2014, 21:39
tim murphy's Avatar
hi big dave that sounds right disconnect the vacuum hose and plug it engine speed up 2 to 3000rpm turn distributor clockwise see how you go going a write up on my this weekend first you must set the bottom pulley to o and make sure your top pulley mark is at the top of cylinder head and turn engine over with a spanner twice cheers
Old 23-05-2014, 19:31
Tim mate which vac hose do you mean? I'm working for the next few days so won't be tinkering with it...
