I'm opening up the ECU tonight to check the resistor.. wherever it may be hiding
![]() I'm getting error 21 (ignition signal) and 22 (fuel pump). I get error 22 before I even start the car, I think it's because of the way the walbro is wired up. Not sure what the best checks are for error 21.. I fitted brand new Magnecor KV85, it run smooth as a peach until it got hot, then it started missing gently, but it was more of a constant gentle miss - which is good in my eyes, more obvious to sort I hope. Now to top it off, I always figured missing below 3k was down to a dodgy o2 sensor - so I check mine.. well it's not likely to work very well given its been replaced with a blanking plug! ![]() |
try this
http://www.scimitarweb.co.uk/sgwrs/v...hp?f=4&t=20398 http://www.scimitarweb.co.uk/sgwrs/v...php?f=4&t=2013
cheers bro, i checked the ecu yesterday, it looks good, no evidence of burning or bulging?
im going to replace the coil. however i cannot get new cam/crank angle sensor anywhere. nissan never sold it separate from the dizzy, n no longer sell the dizzy anyway. no second hand dizzys floating about either ![]() |
mine wont always fire tried 3 ecus 2 distributors plenty of fuel plenty of spark but not always pulse to the injectors
what immobilizer is it?
i would temporary bypass it and see if that makes a difference. most after market ones are cut in line behind the key cylinder. If it is cut into both your starter wire and your ignition wire then it could well be a faulty immobilizer ecu it would be my first port of call .
![]() Quote:
![]() Quote:
My Eunos had a period where it would just cut out at random times, I checked everything, it sent me mad. By chance I found I could make it cut out with having the steering wheel at a certain angle, it was a loose earth on the immobiliser and it looped down near the steering column, when a joint on the column hit it, it would move it just enough to cut it out! Nipped up the earth and it was sorted. |
My mark 1 did the same, warm up then cut out while driving. It was the optical sensor in the distributor, cleaned and replaced that then it was all good. Have a look on US s12 forum I posted some pics of my dizzy on there to give you a better idea
Thread Tools | |
Display Modes | |
