Old 30-04-2006, 18:36
Default FAO shaun
Shaun i beleive you had some copper mainfold gaskets made up? Im fed up with blowing the standard gaskets every other day
Old 30-04-2006, 18:51
hi adz its stella, i know shaun had them done at ferriday engineering. 01785 / 621710.
Old 01-05-2006, 11:40
Any ideas on cost and wether he could get me some made up and posted
Old 01-05-2006, 12:54
when i last rang ferriday shauns gasket pattern was still on file so i would imagine you wouldnt have to send a template if thats still the case
Old 01-05-2006, 13:28
the pair was no more than 15 pounds.give him a bell he'll get you some made and posted.
Old 01-05-2006, 22:38
cool do you have some contact details
Old 01-05-2006, 23:47
hay adz, lay off that right hand, your going blind, i've posted the number
Old 02-05-2006, 02:55
hahah oh yeh
Old 02-05-2006, 09:26
It seems weird that you are getting the gaskets blowing. I've not had any problems with mine.
Have you tried a different manifold? There must be an unmatched surface on either the head or the manifold, it would be better to solve this then getting copper gaskets made up. You'll be pissed if it don't even solve the problem if the mismatch is too bad.
Old 02-05-2006, 13:26
I have a few manifolds so will take a look but im sure i picked the best one i had when i built it all think the main problem lays within my studs coming loose, im gunna have to helicoil 2 more studs now. I only did 3 when i was building it up as the other 3 were solid.But im gunna use copper gaskets too as there gunna be better than the standard ones.
