the 2 2/1" exhaust is it availleble or home made ?
with throttlebody you mean the air-intake after the turbo on topo of the engine right?this part http://www.club-s12.org/forum/showthread.php?t=13164 i still need to learn the technicale name of some parts |
exhaust you will have to make yourself or get made,yes the picture you show is of the throttlebody which wont add much but its better than nothing,i have a z31 turbo one on mine but the ka24 one is bigger still,dont forget to port your inlet manifold where the throttlebody bolts on if you fit one otherwise its a waste of time
ok i will make an exhaust
but do i need to changes a lot for the throttlebody swap or is it just swap and port the inlet manifold oh yes the z31 turbo is going to be a problem i won't find is easy here they are not officialy sold in belgium only the imported would be availleble but the ka24 witch carsand engine are they from ? |
i think its the 240sx that has the ka24e single cam engine that has the large throttle body,its a bolt on job after uve ported the manifold,the water inlets into and out of it may need modifying to bolt it on thougth,there will probably be some information on club s12.com about it
you could just loop the water pipes together, as heat through the throttle body is not good, it could be put back through for winter use, i think its just so the butterfly dont ice up.
240sx that would be a 200sx s13 right?
240sx is not used here only 200sx s13 and s14 or silvia s12 it sucks to live in belgium they don't follow other country with all models and don't always use the same names mayby someone can sell it to me and send it to belgium i thing that's easer than the surge in belgium |
240sx is not the same as 200sx s13 no,s13 throttle body may be be bigger than s12 and go on,not sure never tried it ,if you want a ka24e throttle body go on ebay usa ive seen them come up before for sale
Thread Tools | |
Display Modes | |
