Old 05-06-2006, 17:04
Is that Idle from cold as the Choke should be on. Also could be an Air leak from aroudn the Turbo etc
Old 05-06-2006, 17:25
datdrift's Avatar
datdrift datdrift is offline
idle from warm and still doing it when hot, i don't think the choke works, cos its never idled higher than around 1000rpm.....could be an air leak, but all i changed was the fuel filter and one fuel pipe so i dident disturb any boost pipes......
in second gear its more like 4 - 4500rpm that it hesitates at
anyone think of any parts i should try changing as ive got a few spares
Old 05-06-2006, 17:41
Fuel pressure regulator or blocked fuel pump could be causes. High idle though makes me think choke unit !
Old 06-06-2006, 14:07
datdrift's Avatar
just ran the diagnostics and got 3 codes.....
23 - throttle valve or circuit
24 - ????
31 - no fault
Old 06-06-2006, 14:53
datdrift's Avatar
changed the throttle position sensor, and it sort of fixed the idle.....for a bit, but then it started rising again. did the diagnostics again and it just came up 44.....
Old 06-06-2006, 16:57
datdrift's Avatar
took the fuel pump out to see if it was blocked at all, and it seemed fine, put a spare one in to see if any difference but still the same so i guess next is to change the fuel regulator and/or injectors......
i think it must be fueling, as the more boost i run the earlier in the rev range it happens
Old 23-06-2006, 17:15
datdrift's Avatar
just got around to changing the fuel pressure reg and injectors and it dident make a difference, so now im stuck for ideas
anyone have any suggestions
