Old 05-06-2006, 18:36
RWDSteve's Avatar
RWDSteve RWDSteve is offline
S12oc Newbie
RWDSteve is an unknown quantity at this point
Default Automatic to Manual Conversion, any help/advice?
I was just wondering if anyone could help with regards to converting an auto Silvia s12 to a manual. I'm quite handy with spanners but I could do with some info on whether this idea is worth considering or whether i'll end up with a gearbox that doesn't fit etc.
Also any ideas on sourcing the parts needed would be handy, as i'm a newbie to the world of Silvias
Thanx Steve
Old 05-06-2006, 23:27
You'll need the following :
MkI or MkII G'box and front part of the prop (each is different)
Clutch Pedal
Clutch Master/slave cylinder and piping
Flywheel/Clutch
Modded G'box rear mount
The rear diff is different but I had an Auto in mine, gives better 0/60.
You have to disconnect the Tranny ECU in the rear and the Radiator coolant pipes. Plus I think the plug on the TPS.
I think thats it...
