nope i have not. Its a very easy straight swap conversion
same gearbox and bell housing, same engine mounts same s12 car loom. Just drop in the det engine Use the s13 ecu,loom and loom ancileries ie dropping resistor and power transister and the 3 green top relays s12 power steering and alternator can be used. Cut a chunk out the s12 power steering pump bracket to clear the wider det head or find a s13 bracket You should be able to work it out from there as you go along.If you get stuck You know where we all are to answer any questions.
