there is a screw on the inlet manifold for altering the idle, but it sounds like one of your sensors is not working, try giving the connectors a wiggle and see if it makes any difference?
Like you said could be the Choke sticking open !!!
you can check for leaks using a gas, less messy than wd40
there is a sensor on the inlet manifold side that gets blocked this can caues high or low idle
Thanks for all the replies, I'll have a poke around the engine bay at the weekend.
Its probably an incorrectly setup throttle position sensor
Thanks 30psi, how do I adjust the TPS?
Is it just a case of winding a screw in and out or is it a little more complicated? |
You adjust the pivot of the sensor so that the switch is shut at idle. As soon as the throttle is lifted off of idle the switch is opened.
There is an idle adjustment screw but I would check the above as its usually not setup properly if the throttle body has been removed. |
Thread Tools | |
Display Modes | |
