Old 21-06-2006, 18:48
Originally Posted by turbozx
i have a couple of questions on this subject
the s13 ecu has a speed sensor input, but as far as im aware s12 and Bluebirds turbos dont have a speed sensor, so this cannot be connected does this matter, what did you do?
the other gray area is a feed for the rev counter s13 are driven form the ecu were as s12s take a feed from the coil pack, i have heard that using a feed off each coil pack with a dioide on each can work?
i have a loom made ready to do the conversion in a bluebird turbo but am unsure about these to aspects!
I never connected the speed sensor.It is fine.
Rather than faff about with diodes i just fitted an aftermarket rev counter with shift light on my dash and connected that to the signal wire from the s13 ecu (Yellow / Red stripe=tacho signal). It also works fine.
