Old 10-07-2006, 21:18
Basically you have a pin that is held in by a c clip. You take this off after supporting the door. Then you tap out the upper and lower Brass rings from the hinge and tap in the new ones. If your door pin is worn then this will have to be changed. Take about an hour each side If you take your time
