Old 14-07-2006, 15:50
TOMO200's Avatar
TOMO200 TOMO200 is offline
TOMO200 is an unknown quantity at this point
Default Fitting Aftermarket Cd Player
Hi everyone, can anyone tell me how they fitted there head unit without it sliding back or forward. The orginal supports dont do much apart from holding it up. Please help as im getting sick of listening to nothing.
Thanks
Old 14-07-2006, 16:17
Dr Silvia's Avatar
at the back of the unit theres a little hole that takes a thread (mine was m5) but they may differ.
i turned the supplied bolt into a hook using some 2-3mm diameter solid core steel wire and then hooked a zip tie through this and over a wiring loom hook on the heater unit almost straight behind it. this is sufficient in my experience to hold it from sliding forwards
now on my headunit the surround is one piece with the unit so it cannot slip back past the black surround, but when i fitted brad's newer headunit this was not the case, but sliding the supplied cage in did the job fine
its a little fiddly, but simple and well tested, my headunits have stayed where they belong for 3 years
Old 14-07-2006, 16:20
TOMO200's Avatar
Cheers Paul
Old 14-07-2006, 16:21
TOMO200's Avatar
sorry i was just talking to a paul automatically typed it,
Cheers
Old 14-07-2006, 16:28
Dr Silvia's Avatar
hehe you could've gotten away with it, paul is my middle name
ur welcome dude
