whats the engine spec as a matter of interest? ET or DET etc? boost level, turbo? good numbers
what other things did you see that were 'restricting' power.. were did you see them..?
anybody know who's RR it was
Red Dot/Als junkyard/PowR Rob - I didn't look at pictures, i looked at the car on the stand. plumbing the breathers into the intake is a bad thing, it will lower the octane of the fuel in the cylinder. what 300zx AFM? certainly not a z32. |
I take it you have the det lump instaled & running bigger power than mine, please tell me more on how poor my engine is please. & how i need to mod it to get to your spec
thanks.
What boost were you running? What cams and turbo does it have?
well it's an s13 but 294.1bhp on standard 370cc injectors and standard afm at 0.8bar boost on a GT28RS and a limited edition Ocho chip, the injectors are maxed at 5600rpm so it runs out of torque at that point (well it stops climbing and its a dead flat curve) 720cc injectors and a Q45 AFM soon to be fitted I'd happily play with the mechanical settings but I suspect you'd also free up more power by having a better map which is the aspect I will admit to beeing far less of an expert on. |
you will have been looking at old pictures. the breather is fed back into the air system, not to atmophere. + afm is NOT standard. its from a 300zx. there has been more work carried out nearly prior to the show also.
'dodgy & crapy'. not something i choose to complement someones hard work, own ideas, pride & joy. thanks.
