Old 01-08-2006, 14:33
The old cup is completely ground off. Just slide the tube on and weld round the bottom. You can see where the white paint stops.
It don't matter what length spring you use as you just move the collar up or down to suit. You can see mine is half way down, so I could use a shorter spring and move the collar up. They're 325lb springs
Old 01-08-2006, 14:42
cheers martin.
Old 01-08-2006, 19:27
Did 325lb springs work well for you Martin?
