Old 05-08-2006, 10:26
ramzb's Avatar
ramzb ramzb is offline
Default Steering Wheel
Has anyone got any tips for removing the steering wheel. I've undone everything but it's as tight f@*k even tried beating it with a lump hammer. Do I need some sort of hub puller or is there an easier way?
Old 05-08-2006, 10:40
I pulled my steering wheel off by hand. It helps if you shout at it. Watch out you dontfly back and smack your head when it eventually comes off.
There should just be the one big hut in the centre holding it on................
There are pullers available to do the job and make it light work though
Old 05-08-2006, 11:22
ramzb's Avatar
I've tried shouting at it, swearing at it, hitting it and it still won't budge. Might have to get to welding torch on it
Old 05-08-2006, 17:12
FLEXXX's Avatar
FLEXXX FLEXXX is offline
here is the trick of the trade moment tap the steering wheel in sequence left and right ie left-right-left-right each time harder than before and it will loosen
Old 05-08-2006, 18:02
dont force it,use a bigger hammer
Old 05-08-2006, 18:34
just grab it at either side and as flex said pull one side then the other
Old 05-08-2006, 20:40
Back Seat Chatter!
it depends on the car...actually...it depends if it's mk.I or mk.II lol
both my MK.I's had no problem...I could either rip it off with my hands, or just use a rubber mallet and smack it off as per the above instructions easily.
My MK.II was a different story altogether. Took me a good hour of swearing, pulling, and smashing with my hammer before it started to budge.
Old 06-08-2006, 15:35
blueneon blueneon is offline
blueneon is on a distinguished road
Im glad its not just me that happend to!
1985 Mk1 S12
Old 06-08-2006, 17:14
Oh no, That didnt actually happen to me as i 'watched out'. I saw that one coming a mile away.
Old 07-08-2006, 09:34
TOMO200's Avatar
TOMO200 TOMO200 is offline
TOMO200 is an unknown quantity at this point
Pull left right left right then top bottom top bottom, ive just done it last week with s13eater, came off a treat
