Old 06-12-2005, 08:03
Jash Jash is offline
Jash is on a distinguished road
Smile S12 fuelling????
Hi all,
Iam new on here and I got a fuel .
I have a std silvia and I got a T25 and FMIC to go on it.
What would be the best way to in cress the fuelling and control it, looking to run about 180bhp....ish for starters.
Any help would be grate.
Grate site guys
Old 06-12-2005, 09:58
There isn't much you can do in the way of fueling to be honest. You can try to add a 5th injector setup or maybe use larger injectors via the control of an Apexi SAFC.
However, for your aim of 180bhp its easy to get this with the standard fueling. Just be sure to check the timing and be observant for detonation. 180bhp is achievable at 12psi of boost.
Old 06-12-2005, 11:27
12psi is that all, SWEET
Will I need a aftermarket fuel pres reg or std ok?
Thanks all dude.
Old 06-12-2005, 12:20
Standard regulator is fine at that boost.
I'm on a non standard one, but thats with a larger turbo and 15-17psi...
Old 06-12-2005, 19:15
Martins right and you can push 200+ at the fly on the std reg
Martin do you know what the maximum psi the std reg unit can handle?
the base presure of it is 36.3 or close to that...
36.3 + maximum inlet presure=?????
Any idea if the det reg will handle an additional 19- 22psi or shall i mishion and fit my weber unit?...
