no mayo around the oil cap as that was the first thing i checked before buying the car i think it might be as pukka said condensation will let you know as soon as its a hectic month
Have you done anything to the engine since you have bought the car?
![]() Quote:
no nothing its been parked up since ive got it all i do is start it up every other day just warm it up as im just waitng for some cash so i can order the springs so i can fit the new kyb shocks and grooved discs at the same time will start the car up later this evening and report back on the level of smoke i did realise a small hole from the rear of the exhaust smaller than a 5p piece
ok ive just took off the pipe between the throttle body and turbo on the turbo end there was a small oil puddle in the orange rubber neck is this normal or not as for tghe white smoke it is still there i will get some more fuel and some redex and see what happens as it has been parked up for 6yrs or so apart from that all is well it starts first time the interior is mintas is the body everything is in good order apart from this but youd expect a few bits
It might be the thin pipe is cracked. Its a pig to replace. Very difficulyt to get at. It driops oil on to the hot manifold and makes smoke. My mechanic made a new (colied) pipe and fitted it. Mind you, my turbos just started sounding like a fighter jet on take off...high pitched whistle.....?
http://cgi.ebay.co.uk/GT28R-Dual-Bal...QQcmdZViewItem
will this fit and is it any good on a s12 with std internals and ss zorst,air filter,fmic not forgetting better clutch etc |
