Old 18-09-2006, 21:03
How much will this cost you in total?
What dampers are you using?
Old 18-09-2006, 21:08
they cost me £95 to the door, that was for both sides inc springs, i'am using the kyb's out of my blue s12, they are only a year old.
Old 18-09-2006, 21:19
bargain; Maybe i will do the conversion then....
Old 18-09-2006, 21:23
i'am going to try and get hold of some bigger discs b4 i put them on , if no one can match anything up,i'll just get some disc without the centers and get some bells made up.
Old 19-09-2006, 08:43
You're best to remove the disc and reassemble the hub. Then try to find an S13 disc, wack it on then see if it is central in respect to the caliper. If it is then you could use redrilled S14/300zx discs easy enough.
You may have to use longer wheel studs though, depends on the discs and your wheel & nut combo
Old 19-09-2006, 08:59
i'll have a go, as i have a old z32 disc in the shed, cheers martin.
Old 19-09-2006, 09:01
It will need redrilling to 4 stud first though
