Old 16-10-2006, 20:27
jakezx's Avatar
jakezx jakezx is offline
jakezx is an unknown quantity at this point
Default boost pipe
my turbo boost pipe pop of last night me and garf have put bak on but still not running right just makes loud spluters and hard to start has any one got any ideas what eles to look at help.
the think is the pipe seems tight on
Old 16-10-2006, 20:37
I would say check the pipes again. It may have a splitt in it somewhere. Other than that it would probably be your air flow meter or pipe between the air flow meter and turbo or the plug on the air flow meter. You may of knocked it off while refitting the other pipe.
Old 16-10-2006, 22:35
If its the standard steel pipe from turbo to inlet, these are crap to be honest. There should be a nice rubber bung to make the seal on to the turbo. This could be the issue. Also at slight increases of boost, these have a habit of popping off creating the symptoms u have
Old 16-10-2006, 23:47
Yeah the nice orange rubber bung that perishses
Old 17-10-2006, 11:03
... or trys to dissapear up the hose when refiting to the turbo!
Old 17-10-2006, 13:09
jakezx's Avatar
checked all the air flow pipes and connectors all ok, rubber bung is ok. can you thing of anything else which would cause this problem i will keep you posted.
Old 18-10-2006, 17:48
ive had a look at this, but its been dark both times which hasent helped......and everything seems to be on fine its a low mileage minter with NO rust anywhere, all the connetors look mint etc.....it just turns over and sometimes coughs into life for a few secs then dies.....i pulled the ecu out to see if it would give any clues and all i got was a 44, which i belive means OK.
any ideas
edit; oh yeah and its a compleatly standard auto, stock boost everything
Old 18-10-2006, 18:58
If its nothing of the above and you definatly refitted everything you removed or had popped off then its got nothing to do with it and you need to test everything from scratch
Starting off with......
Is the battery and alternator outputs ok
Have you knocked a dizzy connector off or damaged you king ht lead etc
Then go through and check every connector and join you see and try different air flow meters,coils if you have spares etc
Old 19-10-2006, 16:52
honest_jim honest_jim is offline
honest_jim is an unknown quantity at this point
There are 2 fuse links that run off the battery its worth checking these. Check them with a test light but move them around at the same time to ensure they dont cut out with vibrations. The connectors can go bad but its an easy fix.
Old 23-10-2006, 17:31
jakezx's Avatar
still working on hopfully havin some look at it soon to see what they think tried all the above still no luck dont have a test light though:
