You wont get a chirping noise via a dump valve, the chirping noise comes when the air is forced back through the turbo and sounds through the air filter. However this is mildly quiet compared to when an external wastegate is used.
You technically only need a dump valve at very high boost.
I think the chatter noise sounds best |
yeah but i like dump valve noise as well so am gonna go for one. Hows best to fit it??
can i put a t peice between the intake and turbo just cut it and join with samco hose what size do i need?? Last edited by ollymk1escort; 22-10-2006 at 12:23. |
i think my dump valve pipe is 1" internal dia, so all you need is a bit of tube 1" or 25mm external dia bout 60mm long and get it welded in the pipe between the turbo and the throttle body, and then get a bit of samco or similar 1" internal bout 100mm long to connect the valve to, then the vacum pipe on mine is 'T'ed off the vac pipe that goes to the fuel pressure reg.
hope this helps.
yep weld a outlet on your pipework preferably around 2 inches or so away from where it bolts to the inlet manifolds throttle body. Then the reference pipe that needs to go on top of the dump valve can connect up to a disused blanked outlet that you can find attached to the bulkhead above the hydraulic clutch fluid pot
but the inlet pipe is alloy is it not and i dont know anyone who can weld alloy. Could i solder it? would it be strong enough? The t piece i was talking about as like this also would the dump valve be ok?
http://cgi.ebay.co.uk/BAILEY-PISTON-...QQcmdZViewItem |
not the inlet manifold, (yes that is alloy) you weld it in the crossover pipe, that connects onto the turbo, over the engine, then fits onto the throttle body and the idle managment, if someone already has one fitted to the crossover pipe, can they post it up for these guys please, i have my DV on my cozzie IC.
