#11
still no luck got the day off and trying my best to get the silvia going but still no look help. cheaked ht leads seem ok and the dizzy cap and bost pipe again and all the fuses also the air flow pipe and connectors but still wont fire cannot get the sparks out cannot get spark plug socket down the tight gap
#12
Fuel pump?
don't think its the fuel pump, it makes a noise, and the fuel can be smelt after cranking the engine, almost seems like its flooding......
Have you not got a spare plug you can test for a spark with? At least you'd know that it was getting as far as the plugs that way. Odd problem tho
yeah i have, but i'm working alot at the mo, and so's jake, so its tricky meeting up, etc
coil/coil earth.
Dizzy signal wire. Check voltage.
